Exchange DAG Databases are not being discovered correctly
  • August 3, 2021
  • 604 views
Kamil W
Certified Expert
Hello guys,
I need your help.
The Customer has an Exchange DAG pseudo-client with subclient ‘databases’ configured as a subclient that contains all DAG databases.
They have removed some databases from Exchange DAG nodes (on server level).
However, after click on ‘Discover’ button, deleted databases are still visible as a content.
The CS and Exchange nodes are running 11.20.46. Exchange version is 2016.
I cannot find any hotfix regarding to this issue.
As a workaround, the Customer put deleted databases to default subclient and disabled activity on subclient level.
Any ideas how to fix it?
Rgds,
Kamil
Best answer by Mike Struening
@Kamil W , confirmed the above is correct.  We don’t ‘forget’ databases.  Moving them to a separate subclient is the right path.  We don’t want to lose that discovery so we err on the side of caution.
@Kamil W , I’ll look into this for you, though I know we keep content around even if they are deleted (because they might be down and coming back later).
You’re essentially looking to have content ‘undiscovered’ if I understand?
Kamil W
Certified Expert
  • Certified Expert
  • August 4, 2021
Many thanks Mike! I can always count on you :)
Rgds,
Kamil
Happy to help!!!
