we like to migrate the archive Mailbox Data from Mailbox Classic Agent to the V2 Mailbox Agent - to be able to upgrade from Exchangen 2013 to 2019.
Also a Compliance Mail Journaling Archiving is active.
The Documentation is a bit cryptic about that.
https://documentation.commvault.com/11.24/expert/29238_transitioning_to_exchange_mailbox_agent.html
You cannot import content from the Exchange Compliance Archiver Agent or the Exchange Mailbox Archiver Agent directly to the Exchange Mailbox Agent. However, content that was archived using these agents can coexist with the content that is archived using the Exchange Mailbox Agent. The content that you archived using the Exchange Compliance Archiver Agent or the Exchange Mailbox Archiver Agent is available until it is aged based on the retention period that you defined for these agents.
This sounds like the old Data is not integratable to the Command Center Console?
So we have to implement the Exchange 2019 Journaling newly?
Only the content from the latest cycle is imported.
This means, all other Cycles from Disk can be deleted? Currently we have copied all Inc and Synthetic Full Archive Jobs from Tape Copies (a former admin created selective copies there and some tapes was deleted due aging problems...) to the Disk location. Since then all recalls are working.
Now we want to get rid of this many Synfull jobs and reactivate a usable Tape Copy. Or will we run into recall issues with that only last importet cycle?
If so, would we have the idea of dissolving the archive and restoring mailboxes as PST and adding them to Exchange 2019 step by step?
After you transition to the Exchange Mailbox Agent, messages that you archived using the Exchange Compliance Archiver Agent coexist with the content that is archived using the Exchange Mailbox Agent. You can create an Exchange virtual cloud that provides your end users with the ability to search the archived journal messages seamlessly for messages that were content indexed by both the Search Engine and the Exchange Mailbox Agent index server. For more information see,
What does this mean? What is the Exchange Virtual Cloud?
Hopefully someone can help us to understand this process and share his experiences with us.
Thanks a lot.
Christoph
Best answer by Scott Reynolds
