Failed to mount
  • April 16, 2022
  • 17 replies
  • 1527 views
Recently deployed a FREL for granular level restores but getting failed to mount . Communication is proper and FREL has been restarted
Best answer by Abhi240995
@Mike Struening & @Jos Meijer  Thanks for the assistance , issue got resolved by entering FREL entries into the hostname file
Jos Meijer
Forum|alt.badge.img+16
  • Community All Star
  • April 16, 2022
@Abhi240995
Is this a media agent which has been converted to a FREL or did you deploy the OVA?
Do you have log entries we can look at to identify the underlying issue?
  • April 16, 2022
I deployed V11.24 OVA
Jos Meijer
  • April 17, 2022
Ok great 👍
Can you provide insight in the logs on the FREL? Probably cvd.log or fbr.log if I remember correctly when facing mount issues.
These can be retrieved by connecting via SCP to the FREL or send log files function in the CommCell.
Logs should be in /var/logs/Commvault/Log_Files/
Also are you browsing from a snapshot, disklibrary or tape storage policy copy?
  • April 19, 2022
find attached
  • April 20, 2022
Kindly help
  • April 20, 2022
Logs have been  uploaded , Kindly help
Jos Meijer
  • April 20, 2022
Seems there is a connection failure from the FREL to the vCenter (have anonymized your environment info) :
1625 b5823 04/19 11:06:42 ### CVMWareInfo::Connect() - VISDKCppBridge::Connect failed [Error: ConnectFailure (Connection timed out)]
1625 b5823 04/19 11:06:42 ### CVMManualDiscVMInfoCache::PrepareVMInfo() - Error Connecting - Failed to connect to vCenter server [x.x.x.x] as user [<username>@<domain.suffix>] from access node [STKCVL001].  [Error: ConnectFailure (Connection timed out)]
1625 b5823 04/19 11:06:42 ### CVMManualDiscVMInfoCache::GetVMInfo() - Failed to prepare VMInfo object for x.x.x.x
  • April 20, 2022
Have checked all possible communications and all seemed to working fine . Finally have logged support case
Jos Meijer
  • April 20, 2022
Just to be sure, as the log clearly states an connection error, have you logged on to the FREL and performed command line commands:
  • cd /opt/commvault/Base
  • ./cvping <vcenter ip or dns address> -port 443
  • April 20, 2022
Hi Jos ,
checked cvping and ping are working absolutely fine
Jos Meijer
  • April 20, 2022
Interesting….
If you want I can check the FBR.log, if so please provide the log.
Otherwise I am curious what the outcome of the support case will be.
  • April 20, 2022
Hi josh are u referring init_fbr.logs as dont see anything by fbr.log . just confirm
Jos Meijer
  • April 21, 2022
Deploying a FREL now, will double check and let you know
Jos Meijer
  • April 21, 2022
Encountering some deployment issues in the LAB, will have to fix this first before I can confirm.
Apologies for the inconvenience
@Jos Meijer , know you’re a busy guy 😎
any chance you were able to look at this?
@Abhi240995 same question….any updates on your side?
  • May 16, 2022
Glad to hear it!!!
