how to delete commvault client instance
  • October 31, 2021
  • 2269 views
Marwa
Novice
i have two instance 01 &02 and I want to remove these instance and create a new one but I don't know how to delete these instance
Best answer by SparshGupta
Hi Marwa
You can use cvpkgrm utility to delete the instances. However, please note that the backed up data might not be recoverable once the instances are deleted.
https://documentation.commvault.com/11.24/expert/2748_uninstall_commvault_from_client_and_mediaagent_computers.html
https://documentation.commvault.com/11.24/expert/2772_uninstalling_commvault_locally_from_unix_and_linux_clients.html
Sparsh
Marwa
Novice
  • October 31, 2021
I used cvpkgadd remove but it doesn't work
SparshGupta
  • October 31, 2021
Hi Marwa
Sparsh
