how to move MA from ComCell1 to ComCell2?
  • January 19, 2022
  • 62 views
I’d like to move one MA from ComCell1 to ComCell2, what is the process? After migration, may I use CommCell2 to restore file from MA which backed up three months ago?
Best answer by Mike Struening
Hi @xiwen !
The process to move clients from CommCell 1 to CommCell 2 is called a CommCell Migration:
https://documentation.commvault.com/11.24/expert/5078_commcell_migration_overview.html
You generally move clients, and as a result move the library access over.
Check out the doc above and see if you have any questions.
Hi @xiwen !
  • January 20, 2022
We run IntelliSnap backup for Azure VM and AWS EC2 on CommCell1, I referred below link, Commvault doesn’t support ComCell migration for Amazon and Azure?
https://documentation.commvault.com/11.24/expert/5154_commcell_migration_support.html
That’s correct.
What is your end goal here?  Are you looking to move a client permanently to another CommCell going forward, or to restore data to another place?
@xiwen , following up on this one.  Can you confirm your end goal so we can make an ideal suggestion?
