I’d like to move one MA from ComCell1 to ComCell2, what is the process? After migration, may I use CommCell2 to restore file from MA which backed up three months ago?
Best answer by Mike Struening
View originalI’d like to move one MA from ComCell1 to ComCell2, what is the process? After migration, may I use CommCell2 to restore file from MA which backed up three months ago?
View originalHi
The process to move clients from CommCell 1 to CommCell 2 is called a CommCell Migration:
https://documentation.commvault.com/11.24/expert/5078_commcell_migration_overview.html
You generally move clients, and as a result move the library access over.
Check out the doc above and see if you have any questions.
We run IntelliSnap backup for Azure VM and AWS EC2 on CommCell1, I referred below link, Commvault doesn’t support ComCell migration for Amazon and Azure?
https://documentation.commvault.com/11.24/expert/5154_commcell_migration_support.html
That’s correct.
What is your end goal here? Are you looking to move a client permanently to another CommCell going forward, or to restore data to another place?
