I need to know difference between Commserve LiveSync and DR
Best answer by dude
View originalI need to know difference between Commserve LiveSync and DR
Best answer by dude
View originalCommServe DR is a “basic” backup of your CommServe Database scheduled on a daily basis and with its own storage policy. This option offers the ability to restore your CommServe however it can take an extended period of time. No replication here. Refer: https://documentation.commvault.com/commvault/v11_sp20/article?p=43516_1.htm
CommServe LiveSync (HA) - you configure a secondary instance, where replication of its database happens every xx mins/hours depending on your environment and in case of a disaster at your PROD site where your Master CommServe is located you can switch to the Secondary CommServe pretty quick. Refer https://documentation.commvault.com/commvault/v11_sp20/article?p=102841.htm
It comes back to the criticality of your environment, RTO etc.
