index v2 upgrade workflow oracle clients above oracle 8
  • 16 May 2023
  • 39 views
Userlevel 2
Badge +5
example of versions for oracle.
hi,
a customer of ours was trying to upgrade all clients to indexing V2.
but the for oracle it only states that oracle 8 and Rac are supported. (or that is how i am reading it)
so my question is can we upgrade later versions of oracle with this workflow?
regards,
Thos Gieskes.
Badge +14
Hi @Thos Gieskes
This is the supported Agents:
https://documentation.commvault.com/2022e/expert/10755_agents_that_use_indexing_indexing_version_1_and_indexing_version_2.html
Only OS Oracle 8 and below are supported for the Oracle Agent:
https://documentation.commvault.com/2022e/expert/3044_oracle_system_requirements.html
Sebastien
Userlevel 2
Badge +5
hi sebastian,
just to clarify this for our internal docs.
so the oracle 8 in the upgrade workflow refers to Oracle 8 linux version not the oracle database version itself?
kind regards,
Thos Gieskes,
Badge +14
Hi @Thos Gieskes ,
I have successfully upgraded an Oracle Agent (DB 19.0.0) to V2 Indexing in my lab, however, can you log a case with Support so we can check your environment and confirm please?
Sebastien
