Is there a way to control when the synthetic full in a server plan runs?
  • 31 May 2023
  • 80 views
Userlevel 2
Badge +11
I am still tryin to get used to server plans. Consider the following requirements:
  • weekly full backups on Fridays
  • incrementals on the other days of the week
If I create a server plan, with a 1 week retention, I understand it will run a synth full every 7 days. but when? will it be on Friday? Can I control this via backup window?
If I do not have a full backup windows defined in the plan, synth fulls are controlled by the backup window as the incrementals?
Pedro
Badge +14
Hi @PedroRocha ,
Can you check this Post for a similar question:
Sebastien
Userlevel 2
Badge +3
@PedroRocha
To ensure that synthetic full runs on preferred day of week, you can use Blackout Window for Synthetic full operation at Global System, Company or Server group levels.
Creating a Blackout Window (commvault.com)
Userlevel 2
Badge +11
Hi @PedroRocha ,
Sebastien
So, you would suggest me to change the automatically created synth full schedule from automatic to manual and indicate it to run weekly?
Userlevel 2
Badge +11
@PedroRocha
So, if there's an automatic synth full schedule to run every seven days, I would create a blackout window excluding sat-thu, so it would run on friday?
