Is there a way to get the snap list in Commcell console for EC2 instances for intellisnap backups?
  • September 7, 2021
  • 52 views
We are performing the intellisnap backups for AWS EC2 instances.
Best answer by Gopinath
Hello Girsh,
From Array management, select your AWS virtualization array entry and use list snaps option. That will list snaps on all protected EC2 instance with intelliSnap under that virtualization client.
Regards
Gopinath
Forum|alt.badge.img+8
  • September 7, 2021
Hello Girsh,
Regards
Gopinath
Thanks Gopinath, that helps.
