ISSUE INSTALLING MEDIA AGENT
  • October 7, 2021
  • 7 replies
  • 235 views
PLS HELP i want to add media agent  to existing installation in AIX server that have oracle server install
i encounter this error
Path commvault/commvault/MediaAgentCache Does not start with root (/), please provide absolute path names starting with root(/).
Best answer by Gowri Shankar
Hi @Tinket
Looks like a / is missing in the path specified
Error : commvault/commvault/MediaAgentCache
Try changing it with absolute path starting with “/” for example /commvault/commvault/MediaAgentCache
Let us know in case of any other questions
Forum|alt.badge.img+13
  • October 7, 2021
Hi @Tinket
  • October 16, 2021
Thanks for ur respond, I HV to get commvault support to help me look at it which he advised we change the custom package but we are still on it once done I will share the solution thanks.
Thanks, @Alexzy !  I unmarked the Best Answer above in anticipation of you sharing the solution.
@Alexzy , did you get a chance to open a ticket for this?  Can you share the incident number with me?
  • October 29, 2021
my boss said he will check it, let see hw he can help if not ...
Thanks, keep me posted!
Hi @Alexzy , following up to see if you got this resolved (or opened a case).
