MSP Specialist
  • January 19, 2021
  • 10 replies
  • 283 views
is there any technical person in commvault available for MSP related topics and questions?
I have get the information that could be a little bit diffiicult, but for me us an MSP Partner it is a little bit difficult this answer, so may someone knows someone which is able to discuss with us some msp related points?
many thanks and best Regards
Philipp
Best answer by Stuart Painter
Hi Philipp
Thanks to Marek in our SE team, he has found a couple of reports that show Office 365 use and Application license consumption by user.
You can generate a report to show Office 365 users with this guide:
https://documentation.commvault.com/11.22/essential/others/pdf/Service_Provider_Solutions_Using_the_Billing_Details_Report.pdf
But this only shows the total number of Office 365 users and not granular detail about which apps.
On Commvault Cloud https://cloud.commvault.com we have Office 365 Exchange Usage report and License Summary reports:
Office 365 and Exchange Usage report on
License Summary - Worldwide report
User Licenses > Application Users subsection
License Summary - Worldwide > User Licenses > Application Users
Distinct users consuming Application User License
The team is reaching out to you to see if we can cover any other queries, please let me know if this answers the question or if you need anything else.
Stuart
And thanks to Marek for finding these report details.
Forum|alt.badge.img+24
  • January 19, 2021
Hey Philipp, are you looking for a more technically oriented discussion or more around MSP service design, pricing, partner program etc?
For technical questions feel free to post here and we can pull in all the experts to help. Otherwise, we can find somebody internally to connect with you.
  • Certified Expert
  • January 19, 2021
Damian, many thanks for your response. We are looking on MSP Reports for example, because we have a lot of problems with the company related reports at the moment and i want to know on which way another msp do the chargeback ! For example we deploy our msp environment for ms365 at the moment and we are sell this on user base but in commvault you can not run a report how many onedrive users are in the backup only for mail is it available and so on.
Philipp
  • Certified Expert
  • January 19, 2021
it is now under solved because i have clicked the wrong button :)
Hi Philipp thank you for the question, I have unmarked the answer for you to leave this topic open and continue the discussion.
I’ll take a look at reporting capabilities for you, some that spring to mind initially are:
License Summary Report (as you suggest reports on user mailboxes as this is how licenses are consumed)
Commvault Cloud report License Usage
Chargeback Report, but again I’m not sure what granularity this provides for One Drive protection.
Hi Philipp
I’m still looking into reporting for you, I’m seeing the same as you, OneDrive doesn’t appear to be explicitly shown in standard reporting.
Please allow me some more time to look into this for you and consult internally.
Stuart
Hi Philipp
Stuart
  • Certified Expert
  • January 24, 2021
thanks Stuart for your replply - is this report also available to download to have it in the commcell directly ?
Many thanks and best Regards
Philipp
  • Certified Expert
  • January 24, 2021
i have now checked and i dont find this but we are in contact with Marek - what we need is an report which is showing the amount of users and the amount of fet for archive and backup
Philipp
Hi Philipp, the 2 reports shown above are hosted on Commvault Cloud, they are not available separately.
The 2 reports listed will provide counts of users against types licenses, but for FET you will need to use License Usage, License Summary or Chargeback reports, which will show FET at a higher level by license type
If you need something more specific or customized to show particular figures, Marek and the team will be able to help with a Customization request.
  • Certified Expert
  • January 24, 2021
thanks for your reply we will discuss this with Marek and his team !
