Hi everyone
I’ve got a bit of a strange one. I’ve created a Plan and in there I’ve defined PostgreSQL as the backup target.
I’ve run through everything as I need it to be and the plan is successfully created.
However, the schedules don’t run as I get the below error (tried to manually start the schedule too):
‘failed to start backups as no eligible subclients were found’
If I backup the DB from the subclient level, I have no problems.
I’ve not assigned anything in the default created subclient policies, so not sure what else may be the issue here?
Best answer by Meera
