Problem with block replication
  • 1 June 2023
  • 73 views
Badge +3
I have a problem with block replication.
2 physical servers with windows, on the third one I have RP store.
On each I have a CV agent.  The data is replicating but without recovery points.
Synchronization status   - Replicating, with problems, Failed to open RP Store, will continue replicating in latest recovery mode until RP Store comes back online.
BLrSvc error is 150:127
Can't find any solution for this problem.
Best answer by NVFD411 2 June 2023, 23:43
Userlevel 2
Badge +7
@Jakub - Would you be able to share the mediamanager.log? Or review for any errors indicating issues with RPstore request. Same with the BlrSvc.log
Mark
Badge +3
Hi @NVFD411,
Thank you for your interest in this problem.
Both logs are large and contain data from other jobs which I would prefer not to make public so I paste only the fragments that relate to the problem, if you need others let me know what to look for.
BlrSvc.log
5928 1be0 06/01 14:05:32 ### Number of Boot VMs=0, client id=33
5928 1b60 06/01 14:05:59 ### TPool [WriterPool]. Ser# [0] Tot [1], Pend [1], Comp [0], Max Par [0], Avg Work Time [0.00 s], Avg Wait Time [0.00 s]
5928 1b60 06/01 14:05:59 ### TPool [IOCPServerPool_blr_gui_msgs_client]. Ser# [1] Tot [20], Pend [20], Comp [0], Max Par [0], Avg Work Time [0.00 s], Avg Wait Time [0.00 s]
5928 1be0 06/01 14:06:32 ### Number of Boot VMs=0, client id=33
5928 1be0 06/01 14:07:32 ### Number of Boot VMs=0, client id=33
5928 1840 06/01 14:08:31 7 [malo*****] BlrWinFsDriver::insMarker() - Marker inserted at seqnum=96157
5928 aa8 06/01 14:08:31 7 [malo*****] BlrHead::addEvent() - Exception for pair 7: Failed to open RP Store, will continue replicating in latest recovery mode until RP Store comes back online.
mediamannager.log:
4980 1a4c 06/02 10:23:23 ----- DELETEAF [ ] MediaManager\MMCIPruneFastOnly reg key not defined. Both Solr and Fast clouds will be pruned.
4980 1a4c 06/02 10:23:23 ----- DELETEAF [ ] New style pruning is active. Only Fast clouds will be pruned.
4980 19a4 06/02 10:23:34 ----- MNTPATH [ ] Request RPStores info for rpStoreId[4] appId[0] hostId [34].
4980 19a4 06/02 10:23:34 ##### CVMMDBMountPath::getRPStoreConfigForHost() - :cvmmdbmountpath.cpp:1673: Failed to get the deviceController Info for hostId [34] and Device[8]. Error[319, There are no devices configured for this MediaAgent.] dbErr[0]
4980 19a4 06/02 10:23:34 ##### MLMMountPath::handleGetRPStoreConfigReq() - :mlmmountpath.cpp:16461: Failed to get RP Stores associated with HostId [34], due to error [319, There are no devices configured for this MediaAgent.].
4980 1b14 06/02 10:23:58 ##### MLMMountPath::handleGetDataServerAccessClientList() - No client access list for client[CommVault], path[].
4980 1628 06/02 10:27:49 ##### TPool [MMSvcThPool]. Ser# [0] Tot [65], Pend [0], Comp [65], Max Par [1], Avg Work Time [10.51 ms], Avg Wait Time [24.37 us]
4980 1628 06/02 10:27:49 ##### TPool [MMArMgrThPool]. Ser# [0] Tot [11], Pend [0], Comp [11], Max Par [1], Avg Work Time [45.66 ms], Avg Wait Time [25.57 us]
4980 1628 06/02 10:27:49 ##### TPool [IOCPServerPool_MediaManager]. Ser# [1] Tot [4], Pend [4], Comp [0], Max Par [0], Avg Work Time [0.00 s], Avg Wait Time [0.00 s]
4980 1628 06/02 10:27:49 ##### TPool [MediaManager]. Ser# [0] Tot [5], Pend [0], Comp [5], Max Par [1], Avg Work Time [15.00 us], Avg Wait Time [27.11 us]
4980 1628 06/02 10:27:49 ##### TPool [MediaManager]. Ser# [1] Tot [120], Pend [0], Comp [120], Max Par [1], Avg Work Time [83.24 us], Avg Wait Time [38.50 us]
Userlevel 2
Badge +7
@Jakub - Thanks for sharing the snippets of the logs.  It appears that host 34 (possibly a media agent) needs to be added to the RP Store using the properties page.
Badge +3
Hey  @NVFD411 !
Thanks for your help ! The problem was in connecting the media agents to the RP store. I managed to solve it.
I still have a question how to recover the data,  if I replicate them in point in time mode ?
Greetings,
Jakub
