Problems share File system Mount Path
  • 27 September 2021
  • 723 views
Badge +13
I have a problem with share Mount Path MS Windows to another. The permission are equals, I have another share with the same permissions.
Have someone idea?
But this permission dont work, bellow the error:
Best answer by Fernando Souza 29 September 2021, 16:22
Hey @Fernando Souza !  Hope all is well!
Can you clarify the issue a bit?  Are you trying to create a windows Mount Path to be used as part of a Disk Library?
I see various different cases in our incident database for this error, though for various uses.
However, the causes are generally environmental.  Here’s a thread from Microsoft:
https://answers.microsoft.com/en-us/windows/forum/all/the-file-or-directory-is-corrupted-and-unreadable/bdb36827-f84f-42c1-bf28-5b2c17279cf1
Userlevel 5
Badge +13
This error message is due to Ransomware protection enabled on the Media Agent. You are trying to share a mount path on a Windows Media Agent (with another Media Agent) This is done using DataServer-IP from the java console GUI. We do not share via Windows between Media Agents since years.
Badge +13
The problem was solved, ran CHKDSK on the partition.
