Why is the 'retain until' date different?
Best answer by Damian Andre
View originalDo you have multiple copies for this job? the ‘retain until’ is based upon days retention only (not cycles) - it may be different on different copies. If you use the data forecast and retention report, you can get a specific estimated age date as well as what is keeping it in retention (days, cycles, required for auxcopy etc.)
The media view looks like tape media but in your other screenshot I see reference to a disk library, so that would explain it (retention difference between copies).
Thank you.
The data cannot be automatically deleted even after the retain unit has passed
Is it because the cycle is not satisfied?
Thank you.
That’s exactly right - that’s why the data forecast and retention report is the best to determine why a job may not be aging - it has a column that displays the exact reason.
Here’s an ‘old but gold video’ that may be helpful!
Thank you for you advise.
