Retired clients report
  • April 10, 2022
  • 297 views
Forum|alt.badge.img+9
Is there a way to search for retired clients in the job summary reports ?
Would someone that Commvault think about putting button that is unchecked by default to show client that are retired.
Best answer by Sean Crifasi
Hi @gary mcneely
- The Web Console report “Commcell Configuration” can be used to identify this information.
- If you can’t find this report you can download this from the store with the link below then import this to your Web Console
-- https://cloud.commvault.com/webconsole/softwarestore/#!/135/663/13926
-- https://documentation.commvault.com/11.24/essential/97429_importing_report_templates.html
A retired client will show as deconfigured in the report.
Sean Crifasi
  • April 10, 2022
Hi @gary mcneely
