Is it possible to configure Universal Command Center when commcells are configured to use RADIUS and external two factor authentication? It appears to me this is not supported.
Best answer by Mike Struening
Sharing case resolution:
Since the Commvault Domain is configured to use Radius for all logins I CANNOT login with a user who doesn’t use MFA.
