We are trying to configure Alerts for failed backups. Tested a few scenarios out and it seems there is no way to get notified about failed backup via the access nodes.
The access nodes(proxies) are carrying out backup jobs for multiple instances and hoped we would be able to set up only 1 alert definitions for those instances instead of creating individual alerts for all our instances. (plus we hope to be future proof with this, so if any new instances are being onboarded, then we don’t need to amend/create any alerts).
Could you confirm that failed backup alerts cannot be configured via access nodes in such way?
Is there any alternative that allows us to automatically add newly onboarded instances to alerts to check for failed backups?
Alert via Access nodes?
Best answer by gszoll
Just to give an update in case someone runs into the same issue:
it is not possible to configure it via proxy nodes. The closest solution is to tick “Instances” on Commserve(not possible via UI), but in that case it will incorporate all type of backups, not just database level.
