Ansible push_servicepack_and_hotfix 101 Response was not success
  • October 13, 2021
  • 351 views
I am new to CVPySDK and Ansible.
I made successfuly a playbook which installation Agent on Linux machines.
Now I try to update agent (push)  from the commcell.
I use the push_servicepack_and_hotfix method but it it returns an error 101 Response was not success.
How could I have more detail to debug this error ?
TASK [Push Service Packs and Hotfixes] ********************************************************************************************************************************************************************************
An exception occurred during task execution. To see the full traceback, use -vvv. The error was: cvpysdk.exception.SDKException: Response was not success
fatal: [localhost]: FAILED! => {"changed": false, "module_stderr": "Traceback (most recent call last):\n  File \"/root/.ansible/tmp/ansible-tmp-1634128027.0540986-7125-68037601934166/AnsiballZ_commvault.py\", line 102, in <module>\n    _ansiballz_main()\n  File \"/root/.ansible/tmp/ansible-tmp-1634128027.0540986-7125-68037601934166/AnsiballZ_commvault.py\", line 94, in _ansiballz_main\n    invoke_module(zipped_mod, temp_path, ANSIBALLZ_PARAMS)\n  File \"/root/.ansible/tmp/ansible-tmp-1634128027.0540986-7125-68037601934166/AnsiballZ_commvault.py\", line 40, in invoke_module\n    runpy.run_module(mod_name='ansible.modules.commvault', init_globals=None, run_name='__main__', alter_sys=True)\n  File \"/usr/lib64/python3.6/runpy.py\", line 205, in run_module\n    return _run_module_code(code, init_globals, run_name, mod_spec)\n  File \"/usr/lib64/python3.6/runpy.py\", line 96, in _run_module_code\n    mod_name, mod_spec, pkg_name, script_name)\n  File \"/usr/lib64/python3.6/runpy.py\", line 85, in _run_code\n    exec(code, run_globals)\n  File \"/tmp/ansible_commvault_payload_7gc73cgq/ansible_commvault_payload.zip/ansible/modules/commvault.py\", line 351, in <module>\n  File \"/tmp/ansible_commvault_payload_7gc73cgq/ansible_commvault_payload.zip/ansible/modules/commvault.py\", line 338, in main\n  File \"<string>\", line 1, in <module>\n  File \"/root/workspace/playbooks-commvault/venv_cvlt/lib64/python3.6/site-packages/cvpysdk/commcell.py\", line 2096, in push_servicepack_and_hotfix\n    maintenance_release_only=maintenance_release_only\n  File \"/root/workspace/playbooks-commvault/venv_cvlt/lib64/python3.6/site-packages/cvpysdk/deployment/install.py\", line 340, in push_servicepack_and_hotfix\n    raise SDKException('Response', '101')\ncvpysdk.exception.SDKException: Response was not success\n", "module_stdout": "", "msg": "MODULE FAILURE\nSee stdout/stderr for the exact error", "rc": 1}
My playbook, login is OK :
 tasks:
    - name: Commvault commcell initialization
      block:
        - name: Login
          commvault:
            operation: LOGIN
            entity: {
              webconsole_hostname: "#####",
              commcell_username: "#####",
              commcell_password: "#####"
          register: commcell
        - debug:
            msg: "Login is done successfully"
      rescue:
        - debug:
            msg: 'Login failed'
    - name: Push Service Packs and Hotfixes
      commvault:
        operation: push_servicepack_and_hotfix
        entity_type: commcell
        commcell: "{{ commcell }}"
        args:
            client_computers: ["la7lnx0001"],
      register: reg_install_job
Thanks in advance for your help
JF
Best answer by cgrau
Hi @Greg Smolen ,
Thanks for your help.
It was a permission problem, the account used has not enough privileges to push and install software on the client.
JF
  • 14 replies
  • October 13, 2021
Hi @cgrau,
Can you verify if the information for running these commands derives from this below page:
→ https://github.com/Commvault/cvpysdk/blob/master/cvpysdk/commcell.py
If not, is there another location you’re pulling the info from? Also, you mentioned you did the push via the CommCell. So this was a Push Update software Job that ran or is there something else?
Greg
  • Bit
  • October 13, 2021
Hi Greg,
Thanks for your answer. Yes, Everything seems in adequation with this documentation.
I try to put a false client name and it returns an another error which say wrong client name. So it seems to have found the client, although I have the error mentionned : 101 Response was not success.
I try to push update from the commcell via this command/ansible playbook.
Sincerely,
JF
  • 14 replies
  • October 13, 2021
H @cgrau,
There may be more information within UpdateInfo.log on the server and possibly in the messages log as well as to why the Updates failed. I suggest opening a case with Support to have someone review this further.
Greg
  • Bit
  • October 14, 2021
Hi @Greg Smolen ,
JF
Forum|alt.badge.img+23
Thanks for sharing, @cgrau !  I marked your reply as the Best Answer.
Cookie policy
Cookie settings
