API for mssql db clone
  • November 17, 2022
  • 127 views
Hello Community
Issue:
I’m trying to schedule mssql db clone via Command center, and there is no such option.
Looking to clone db via CV API or Sending QCommands as a API Json request
Tried:
While manually creating mssql db clone via command/admin center, noticed there is a Json Post Request Payload for instance clone.  Search in CV BOL, and nothing but how to View DB Clone via .py script
https://documentation.commvault.com/11.24/essential/45532_samples_for_developer_sdk_for_python.html#viewing-instant-clones
Questions:
the db clone has a payload request, from where I can find the related Post Request Syntax (example:  'http://<webserver>:port/SearchSvc/CVWebService.svc/databases/Action_XXX/clones_XXX') for mssql DB clone, thanks
Or
CV Syntax example is for XML and I want to make it work for Json.
Can I use ‘inputRequestJson’ to get Json Request Payload that shows in above screenshot?
https://documentation.commvault.com/2022e/essential/48618_rest_api_post_execute_qcommand.html
Best answer by Jos Meijer
Hi @DanC
The json method for QCommand via REST is described here:
https://api.commvault.com/#abade427-7892-4ea4-b6de-5c15b97241c8
Example request:
$headers = New-Object "System.Collections.Generic.Dictionary[[String],[String]]" $headers.Add("Accept", "application/json") $headers.Add("Authtoken", "QSDK token would be auto set after POST Login is called.") $headers.Add("Content-Type", "application/x-www-form-urlencoded") $body = "command=qoperation%20execute&inputRequestXML=%3CTMMsg_InstallPackageListReq%20includeOnlyInstalledPackages%3D%221%22%20installOSType%3D%22100%22%20requestForUninstall%3D%221%22%3E%3CclientEntity%20clientId%3D%222%22%2F%3E%3C%2FTMMsg_InstallPackageListReq%3E" $response = Invoke-RestMethod 'http://WebConsoleHostName/webconsole/api/ExecuteQCommand' -Method 'POST' -Headers $headers -Body $body $response | ConvertTo-Json
Hope this helps.
Jos Meijer
Forum|alt.badge.img+21
  • Community All Star
  • November 18, 2022
Hi @DanC
Example request:
Hope this helps.
  • November 22, 2022
@Jos Meijer  thank you
the example only for XML input (inputRequestXML)
I want to use JSON request payload via QCommand and How to put JSON input request to qoperation?  something like inputRequestJSON instead of inputRequestXML but I can’t find anything
