api for sql availability group instance
  • November 1, 2024
  • 68 views
Hello team
Referring to the previous thread, we're currently on version 11.32.63, and the “equivalent API” option isn’t available in the Command Center. Could you let us know which service pack includes this feature, or where we might be able to locate this option? Thank you!
@DanC
You noted previous thread is there another thread? I could not find one could you link it?
From your screenshot this is the add an instance page in Command Center and you are saying that the highlighted button in your 32.63 Command Center is not even there, or it doesn't work as expected?
  • November 1, 2024
@Scott Reynolds
the highlighted button “equivalent API” not in 32.63 command center
this is old thread i’m referring to
https://community.commvault.com/developer%2Dtools%2Dintegration%2Dand%2Dautomation%2D50/rest%2Dapi%2Dto%2Dcreate%2Dmssql%2Dserver%2Davailabilitygroup%2D8191
Hello ​@DanC
I am not certain if there was a specific service pack however, I tested this on a FR34 and FR36 and the button is there as expected.
