API to create Global Secondary Copy Policy
  • December 29, 2022
  • 92 views
Winov
Novice
Hello guys.
I'm trying to find an API to create a secondary copy of an existing Storage Policy.
I need to create this copy as a Global Secondary Copy Policy to use a Storage Poll that already exists.
When I call the '/V2/StoragePolicy/35/Copy' API with the parameters
       $data = '{
         "copyName": "2-CP-TAPE",
         "useGlobalPolicy": {
           "storagePolicyName":"SPOOL-TAPE-1WEEK"
         "storagePolicyCopyInfo": {
           "active": 1,
           "isDefault": 0,
           "extendedFlags": {
             "useGlobalAuxCopyPolicy":1,
             "chunkLevelAuxCopy":1
           "library": {
             "libraryName":"TAPE-VIRTUAL1",
             "libraryId":3
           "mediaAgent": {
             "mediaAgentId":2,
             "mediaAgentName":"wzsp2-csnfr"
           "storagePool": {
             "storagePoolName":"SPOOL-TAPE-1WEEK",
             "storagePoolId":18
I get the following message
{ "processinginstructioninfo":{ "attributes":[ { "name":"WebServer","value":"WZSP2-CSNFR" } ] },"error":{ "errorMessage":"'Pick data from running jobs' feature is not supported for selective copy or Inline copy.","errorCode":1 } }
Could you help me?
Best answer by Winov
I solved the problem running this API
$data = '{
          "active": 1,
          "isDefault": 0,
          "copyType": "SYNCHRONOUS",
          "extendedFlags": {
            "useGlobalAuxCopyPolicy": 1,
            "overRideGACPRetention": 0
          "retentionRules": {
            "retainArchiverDataForDays": -1
          "globalAuxCopy": {
            "storagePolicyId": 18,
            "storagePolicyName": "SPOOL-TAPE-1WEEK"
          "dedupeFlags": {
            "enableDeduplication": 0
Thaks
Winov
Novice
  • December 29, 2022
$data = '{
          "active": 1,
          "isDefault": 0,
          "extendedFlags": {
          "retentionRules": {
          "globalAuxCopy": {
          "dedupeFlags": {
Thaks
Forum|alt.badge.img+18
  • December 29, 2022
Great news.  Thank you for the update!
