API to Fetch "Reason for job delay" (error/Failure message of job)
  • May 21, 2024
  • 79 views
Can you please provide API to Fetch "Reason for job delay" message (error/Failure message of job)
Hi @Heemansu Gehlot,
We can use job summary API to get the error/failure reason for a job. Reason will be listed under “pendingReason”.
You can find more details here.
Example of the API:
GET {{ServerUrl}}/Job/1405
Response:
    "totalRecordsWithoutPaging": 1,
    "jobs": [
            "jobSummary": {
                "sizeOfApplication": 0,
                "vsaParentJobID": 0,
                "backupSetName": "defaultBackupSet",
                "opType": 4,
                "isAnomalous": true,
                "totalFailedFolders": 0,
                "distributedAppsClusterType": 7007,
                "totalFailedFiles": 0,
                "jobAttributes": 288230376151711744,
                "isAged": false,
                "sizeOfMediaOnDisk": 0,
                "currentPhase": 7,
                "status": "Waiting",
                "percentSavings": 0,
                "localizedOperationName": "Backup",
                "estMediaSize": 0,
                "backupLevel": 1,
                "jobElapsedTime": 0,
                "jobStartTime": 1716829211,
                "currentPhaseName": "Backup",
                "isPreemptable": 1,
                "attemptStartTime": -1,
                "appTypeName": "Big Data Apps",
                "currentThroughput": 0,
                "subclientName": "default",
                "destClientName": "azurecloudplan_IndexServer",
                "jobEndTime": 0,
                "commcellId": 2,
                "thresholdTime": 264,
                "phasePercentagesList": "",
                "alertColorLevel": 16,
                "currentPhaseType": 8656384,
                "jobAttributesEx": 65536,
                "isVisible": true,
                "localizedStatus": "Waiting",
                "totalNumOfFiles": 0,
                "jobId": 1405,
                "lastUpdateTime": 0,
                "statusColor": "black",
                "pendingReason": "Library [azurecloud], MediaAgent [vishnu-ws], Drive Pool [DrivePool(vishnu-ws)3], Media[]: Mount path is offline. Advice: Please check if the mount path is online and accessible.  The offline reason shown on mount path properties will indicate why it's unavailable. <br>Source: vishnu-cs, Process: JobManager",
                "errorType": 500,
                "jobType": "Backup",
                "backupLevelName": "Full",
                "pendingReasonErrorCode": "32:406",
                "percentComplete": 20,
                "phaseTimingsList": "",
                "averageThroughput": 0,
                "localizedBackupLevelName": "Full",
                "destinationDisplayClient": {
                    "clientId": 0
                "plan": {
                    "planId": 0
                "destinationClient": {
                    "clientId": 13,
                    "clientName": "azurecloudplan_IndexServer",
                    "displayName": "azurecloudplan_IndexServer"
                "clientGroups": [
                        "_type_": 28,
                        "clientGroupId": 6,
                        "clientGroupName": "Index Servers"
                "dataSource": {
                    "dataSourceId": 0
                "subclient": {
                    "instanceName": "classicIndexInstance",
                    "backupsetId": 16,
                    "commCellName": "vishnu-cs",
                    "instanceId": 6,
                    "workloadId": 7007,
                    "subclientId": 19,
                    "clientId": 13,
                    "appName": "Big Data Apps",
                    "backupsetName": "defaultBackupSet",
                    "applicationId": 64,
                "company": {
                    "companyId": 0,
                    "companyName": "Commcell"
                "storagePolicy": {
                    "storagePolicyName": "azurecloudplan",
                   "storagePolicyId": 8
                "userName": {
                    "userName": "admin",
                    "userId": 1
Vishnu
