Batch adding systems for activate scans, Is this possible?
  • March 11, 2022
  • 42 views
Matthew M. Magbee
Explorer
Activate users, Assemble!!
I noticed that I typically add 1 or 2 systems to projects in activate at a time. IS there a way to batch add or use grouping to complete a mass entry?
Best answer by Tanmay Garg
Hi Matthew,
For FSO, you can use our “Add multiple” feature to add multiple file servers.
This feature is available from FR26. You can find the details below:
https://documentation.commvault.com/11.26/essential/145492_adding_file_server_data_sources_in_bulk_from_command_center.html
For previous feature releases, we have a workflow.
Tanmay
  • March 11, 2022
Hi Matthew,
Tanmay
