Hi All,
I'm looking for technical resources and experience in integrating Commvault with Morpheus.
What is the integration architecture?
Is it possible to match tenant between Morpheus and Commvault? If so, how?
So far, I've found only one link on the subject at Morpheus:
Commvault — Morpheus Docs documentation (morpheusdata.com)
In the integration section of this link, it says to add the IP or Hostname of the CommServe”, but I'm under the impression that it refers to the Web Server (in our architecture, the Web Server is not hosted on the Commserve).
Luc
