created s3 cloud library , now I need to share the mount path to another MA agent using workflow
  • March 21, 2024
  • 78 views
Forum|alt.badge.img+2
  1. I have created s3 cloud library , now I need to share the mount path to another MA agent.
https://documentation.commvault.com/2022e/expert/adding_new_mediaagent_to_cloud_storage_device.html
By Using Device ID
https://documentation.commvault.com/2023e/expert/files/products/media_agent/xml/ShareMountpath.xml
You can use the device ID to share a mount path with one or more MediaAgents
Here I can see sharing mount path using device IDs, I need the same using names, not IDs
I can see xml parameter for Disklibrary , need xml file for cloud lbrary – mount path sharing.
  • March 22, 2024
Hi Neeraj,
I would like you to refer to the below documents,
https://documentation.commvault.com/2023e/expert/adding_new_mediaagent_to_cloud_storage_device.html
https://documentation.commvault.com/2023e/expert/cloud_libraries_vendor_specific_xml_parameters.html
Below are the available attributes.
Attribute
mediaAgentName
The name of the MediaAgent.
libraryName
The name of the new cloud library.
credentialName
The name of the credential that you created using the Credential Manager. If you enter the credential name, then:
  • Update the loginName parameter in the format of "<vendorURL>//__CVCRED__". For example, "s3.amazonaws.com//__CVCRED__".
  • Update a dummy value for the password parameter.
Forum|alt.badge.img+5
  • March 22, 2024
Hello @Neeraj
please check below steps.
By Using Device Name
You can use the device name to add a mount path to a cloud storage library.
Complete the following steps:
  1. Download the add_cloud_mp_device_name.xml file and save it on the computer where the command is run.
  2. Open the XML file.
  3. Change the XML parameters.
    Attribute
    deviceName
    The name of the cloud device that you want to use to configure.
    libraryName
    mediaAgentName
    Example: Use this example XML file to add a mount path to a cloud library with name "Library1", device name "Device1" and MediaAgent name "MA1".
  4. Run the following command from the <software installation directory>\Base folder.
    qoperation execute –af add_cloud_mp_device_name.xml
