Hello good,
We are configuring some reports from the Web report, we have detected that two cases occur when naming the report.
#1 - The name of the pdf file that is sent by mail is the sum of the "Report custom name" field + the "Name" field
#2 - The name of the file that we save in a network path is saved only with the name of the "Report custom name" field.
We are wondering if it is possible in case #2 to save the pdf in the network path with the same name as case #1 explained above.
Is there any way to be able to do it?
Thank you,
All the best.
