I’d like to enable parallel backup config for PostgreSQL databases. I can see I can modify the parallel dump based back up set config to enable parallel backups, but wondering if the default dump based backup set config can have this feature enabled by default?
I don’t find any related article about it.
For reference, this is the attribute I’d like to get enabled by default:
