DELETE SCHEDULE POLICY USING PYTHON OR POSTMAN REST
  • February 20, 2024
  • 9 replies
  • 79 views
Hello Vaulters,
I have been to automate schedule policy delete using by calling the API using the syntax on the document but I keep facing error, does any one have an already executed script or guide and how to achieve this?
  • February 20, 2024
Uchenna,
What is the error that you are getting.
Edward J Holowienka
  • February 21, 2024
Hello Edward
se error attached
  • February 21, 2024
Uchenna,
Where did you get the values 54656 and 54942 from.
Reqards,
Edward J Holowienka
  • February 21, 2024
Hello Edward,
This is 54656 represent the Schedule task ID and 54942 represent the sub taskID gotten from the postman syntax
  • February 21, 2024
Uchenna,
You need to get those values from your environment by running the following;
To get the taskid
GET <webservice>/SchedulePolicy HTTP/1.1
Then you would need to run this to get the subtaskid
GET <webservice>/SchedulePolicy/{taskId} HTTP/1.1
Reqards,
Edward J Holowienka
  • February 21, 2024
Hello Edward,
Exactly what I did but do you have the syntax to delete a schedule policy?
  • February 21, 2024
Uchenna,
Based upon the error that you are getting one of the values is not correct. Do you want to delete the whole schedule policy or just one of the schedules within it.
Edward J Holowienka
  • February 21, 2024
Hello Edward,
  • February 21, 2024
Uchenna,
If that is the case, then this is the call that you should be using
https://documentation.commvault.com/2023e/essential/rest_api_delete_schedule_policy.html
DELETE <webservice>/SchedulePolicy/{taskId} HTTP/1.1
Edward J Holowienka
