Hello Vaulters,
I have been to automate schedule policy delete using by calling the API using the syntax on the document but I keep facing error, does any one have an already executed script or guide and how to achieve this?
Uchenna,
What is the error that you are getting.
Edward J Holowienka
Hello Edward
se error attached
Uchenna,
Where did you get the values 54656 and 54942 from.
Reqards,
Edward J Holowienka
Hello Edward,
This is 54656 represent the Schedule task ID and 54942 represent the sub taskID gotten from the postman syntax
Uchenna,
You need to get those values from your environment by running the following;
To get the taskid
GET <webservice>/SchedulePolicy HTTP/1.1
Then you would need to run this to get the subtaskid
GET <webservice>/SchedulePolicy/{taskId} HTTP/1.1
Reqards,
Edward J Holowienka
Hello Edward,
Exactly what I did but do you have the syntax to delete a schedule policy?
Uchenna,
Based upon the error that you are getting one of the values is not correct. Do you want to delete the whole schedule policy or just one of the schedules within it.
Edward J Holowienka
Hello Edward,
Uchenna,
If that is the case, then this is the call that you should be using
https://documentation.commvault.com/2023e/essential/rest_api_delete_schedule_policy.html
DELETE <webservice>/SchedulePolicy/{taskId} HTTP/1.1
Edward J Holowienka
