Deploy VMware Access Node using API
  • January 13, 2023
  • 7 replies
  • 427 views
Robert Horowski
Hi
I’m trying to deploy Acess Node for VMware using API but can’t seem to get this to work.
I’m using this: https://api.commvault.com/#f9950083-6ef5-487d-9b32-d332b843b64c
with powershell from Commserve computer. I was able to successfully aquire QSDK Token, but when I try to deploy AN I get error:
Here is TaskManager.log fragment:
9456  1     01/13 16:09:11 ### ### ControlTaskMgr - Request received for [Tag_CreateTaskReq], userId [5], commcellId [2], sequenceNumber [1], fromUpgrade [False], endUser [False]
9456 1 01/13 16:09:11 ### ### ControlTaskMgr - Input xml <TMMsg_CreateTaskReq>
<processinginstructioninfo>
<locale _type_="66" localeId="0" />
<formatFlags skipIdToNameConversion="1" />
<user userName="" userId="5" _type_="13" />
</processinginstructioninfo>
<taskInfo>
<subTasks>
<subTask subTaskType="1" operationType="4038" />
<options>
<adminOpts>
<vmProvisioningOption operationType="59">
<virtualMachineOption accessNodeDeploymentType="0">
<password userName="root" />
<vmEntity vmName="XXXXXXXXX-API-Deploy1" _type_="88" />
<configValues value="False" key="beAutomaticOSUpdates" />
<configValues value="True" key="aaUseDHCP" />
<configValues value="XXXXXXXXX-API-Deploy1" key="baClientName" />
<configValues value="XXXXXXXXX" key="bbClientHostname" />
<configValues value="XXXXXXXXX" key="cbCSHostname" />
<configValues value="XXXXXXXXX" key="caCSName" />
<configValues value="" key="bdClientGroup" />
<vmInfo>
<vmLocation hostName="esxi01.XXXXXXXXX" dataCenterName="XXXXXXXXX" inventoryPath="/XXXXXXXXX/vm/XXXXXXXXX" resourcePoolPath="" clusterName="" vCenter="vcenter.XXXXXXXXX">
<datastore name="LUN02" />
</vmLocation>
<vm vmName="XXXXXXXXX-API-Deploy1" _type_="88" />
<advancedProperties>
<networkCards networkName="XXXXXXXXX" />
</advancedProperties>
<hardDisks>
<hardDisk diskType="1" />
</hardDisks>
</vmInfo>
</virtualMachineOption>
</vmProvisioningOption>
</adminOpts>
</options>
</subTasks>
</taskInfo>
</TMMsg_CreateTaskReq>
9456 1 01/13 16:09:11 ### ### ControlTaskMgr - ERROR: ErrorCode[587204001], ErrorString [Failed to create task. Could not insert task into data base [Object reference not set to an instance of an object.]], Message[Received request type Tag_CreateTaskReq]
9456 1 01/13 16:09:11 ### ### TaskMgr.createTask - ErrorString [Failed to create task. Input XML is [<TMMsg_CreateTaskReq>
<taskInfo>
<subTasks>
<options>
<adminOpts>
<vmInfo>
</vmLocation>
<hardDisks>
</hardDisks>
</vmInfo>
</adminOpts>
</options>
</subTasks>
</taskInfo>
</TMMsg_CreateTaskReq>]]
9456 1 01/13 16:09:11 ### ### TaskMgr.createTask - Exception [System.NullReferenceException]. ErrorString [ ...
9456 1 01/13 16:09:11 ### ### TaskMgr.createTask - Exception [System.NullReferenceException] stack trace
at EvTaskMgrManaged.TaskMgr._createTask()
I’ve done the same from Command Center and tried to compare values passed through $body but the only difference I have found that api docs states
`"subTaskType`": `"ADMIN`"
while in log from Command Center initiated job there is
I have tried both but neither seem to work.
I don’t have much experience with API, so maybe I am missing something obvious.
Any ideas what else can I try?
Best answer by Robert Horowski
Hi @Damian Andre
Support came back to me with fixed body file. It still didn’t work from postman, but when I imported it into powershell I was finally able to deploy Access Node. It look like there is a part
which is missing from documentation # https://api.commvault.com/#f9950083-6ef5-487d-9b32-d332b843b64c
I hope docs will be updated soon to reflect that. Have a great weekend!
Cheers!
  • January 14, 2023
@Robert Horowski Good morning.  I apologize for the delay in response.  I reviewed your post with one of our Server team expers and they recommended opening a case with our Server focus group to take a look at this more in depth.  This very well may need to be escalated to Development.
Robert Horowski
  • Community All Star
  • January 16, 2023
Thanks @Orazan I will open a ticket as advised.
Hello
  • January 24, 2023
@Robert Horowski - any luck on this one?
webserver.log may have more detailed information - as well as taskmanager.log
Robert Horowski
  • January 24, 2023
Hi @Damian Andre
I’ve opened a case for this. Support has tested this on their end using Postman and it should work in general. We tried to run this from Postman in my env, but it returns an error that body is invalid and we were not able to find what is wrong with it on the session. Still waiting for the support engineer to come back to me. I will update once we crack this.
  • January 24, 2023
Hi @Damian Andre
Hmm… interesting! Ok lets see how we go - appreciate the update.
Robert Horowski
  • January 27, 2023
Hi @Damian Andre
Cheers!
