Unfortunately, when executing the “qoperation execute -af clone_subclient_template.xml” command, an error occured, saying that VM tags are required to perform the subclient duplication.
Do you have a proper documentation link or XML template to duplicate a subclient and how can I manage the dynamic content based on VM tags?
Thank you in advance,
Best regards,
Best answer by Dave Turner
The XML here is incorrect and looks like it would only support filesystem agent as it is on that link.
I’ve raised the request to get the XML updated to support virtual server agent as well.
However there is an easy fix.
Download the clone_subclient_template.xml and update it with the “vmContent” tag into the XML like so:
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
