exclude User from workflow "DeleteClientAuthorization"
  • August 4, 2025
  • 170 views
I need a user who should delete clients without permission. Can I exclude him somehow in the workflow?
Best answer by Pasqual Döhring
Hi.
In 11.32 you were able to allow users/group to run the multi person authorization workflows without confirmation. I am not sure if that was possible for single workflows but you could set it on the master workflow “GetAndProcessAuthorization” in the configuration:
To get that behaviour back, you need a hidden additional setting in your environment:
Category: CommServDB.Console
Type: Boolean
Value: True
Best regards,
Pasqual
Forum|alt.badge.img+2
  • August 4, 2025
Hello Perabo,
I believe if you add any user or user group who can authenticate the request that user will be able to delete the client without any authentication but still this needs to be tested
  • August 4, 2025
Hi orophile,
thanks for the fast reply. I tested this option but adding a user or group deciedes only who can authorice deleting a client.
Daniel
Pasqual Döhring
Apprentice
Hi.
Type: Boolean
Value: True
Best regards,
Pasqual
  • August 5, 2025
Hi Pasqual,
thanks this works perfect.
Daniel
