Hidden API calls | GET Backupset Browse
  • March 3, 2021
  • 139 views
Forum|alt.badge.img+2
I am currently working on a dedicated workflow to split the content of multiple subclients to have subclients with the same size.
To do that, I would like to perform a “Browse & Restore” on the backup set using API call to retrieve all the volume size and perform my distribution.
I’ve tried to find something like GET /Subclient/{{id}}/Browse?path=%5C call for backup sets but I found nothing.
I tried to perform a GET /Subclient/{{id}}/Browse?path=%5C but the returned status code is 400.
Maybe you will be able to give me a workaround or inform me about hidden API calls?
Thank you in advance for your answers.
Best answer by Yash
@JohnADP The call you’re trying to make is at subclient level. For Backupset level, please refer to this API:
https://api.commvault.com/#0c619151-3c40-44f6-b73e-d7a5b2f8e5dc
(Look for: Browse - Backupset Level on the right column drop down)
Here is an example to browse at backup set level on D drive:
POST {{ServerUrl}}/DoBrowse
"opType": 0,
"queries": [
"type": 1,
"queryId": "countQuery",
"aggrParam": {
"field": 0,
"aggrType": 4
"type": 0,
"queryId": "dataQuery",
"dataParam": {
"sortParam": {
"ascending": true,
"sortBy": [
38,
0
"paging": {
"firstNode": 0,
"pageSize": 15,
"skipNode": 0
"mode": {
"mode": 2
"paths": [
"path": "D:\\"
"options": {
"showDeletedFiles": true,
"restoreIndex": true
"entity": {
"applicationId": 33,
"backupsetId": 3,
"instanceId": 1,
"clientId": 2
  • March 3, 2021
"opType": 0,
"queries": [
"type": 1,
"aggrParam": {
"field": 0,
"aggrType": 4
"type": 0,
"dataParam": {
"sortParam": {
"ascending": true,
"sortBy": [
38,
0
"paging": {
"firstNode": 0,
"pageSize": 15,
"skipNode": 0
"mode": {
"mode": 2
"paths": [
"path": "D:\\"
"options": {
"entity": {
"backupsetId": 3,
"instanceId": 1,
"clientId": 2
  • March 5, 2021
Hello Yash,
Thank you for your answer, it worked just as you said!
