How do I create a list entities to populate a dropdown?
  • February 13, 2024
  • 61 views
christopherlecky
Explorer
Forum|alt.badge.img+16
Is it as simple as create an XML representation of the entity list?
I have been attempting to create it via Java with strange results.
  • February 13, 2024
Hi @christopherlecky,
What type of entities are you trying to list in your dropdown?  We have some built-in Entity lists that can be easily used to populate a drop-down in a PopupInput activity depending on what you need.
You would just select an Variable Type of <Other> and then expand the entries as I have above.
Are you looking for something that’s not included above that you’re looking to pull from a Commserve Database query?
-Brian Bruno
christopherlecky
Explorer
Thanks for answering Brian, but what I am looking for is the ability to populate a predefined variable that is a list of entity type can I generate it as xml?
I know that sounds crazy, but the reason I am asking is because I found a workflow that appears to do exactly that.
I’ll have to take screenshots to elaborate, so I will as soon as I have a free moment.
