How to know when a failover happened and to which node using REST API?
  • March 28, 2024
  • 43 views
Hey! I am developing automation scrips using Commvault APIs for my team. I know the names of primary commserve which I use, BUT whenever a failover happens my API calls of course don’t work as there is no web service active on the primary commserve.
Is there a way to know which node the failover happened to using just the APIs? And also get the list of all failover nodes?
Hello @Prashant Mall
Thanks for the great question.
The following will return the hostname of the CS:
https://api.commvault.com/docs/SP34/api/cv/ControlPanelOperations/get-comm-serv#get-commserv-details
The following will give you Monitoring nodes and fail over nodes:
https://api.commvault.com/docs/SP34/api/cv/CSLiveSync/get-comm-serv-failover#fetch-cslivesync-config
I’m not sure if you can find your answer here but these two would be where i start.
Kind regards
Albert Williams
Kind regards
Albert Williams
