How to set SQL Server authtication using REST API?
  • January 3, 2025
  • 69 views
Friends,
I would like to set the SQL Server Authentication on client level using REST.
If I request the client info using `/client/:clientid`, I see within `clientProperties.pseudoClientInfo.idaInfo.sql61Prop` the override switch and the MSSQLCredentialinfo.
I tried simply to get the client info, update what I want to update and post this back. The response is 0, but nothing is changed.
Does someone knows how I can update this?
Thanks in advance, Maurice
  • January 4, 2025
Hi ​@DUO-CSR
Are we getting same response for all the clients?, Can we try to execute API against another client to re confirm.
  • January 6, 2025
Hello ​@Pradeep
Yes, I have this on all clients.
I reduced the body to only the items what needs to be changed;
$body = @"
"clientProperties": {
"pseudoClientInfo": {
"idaInfo": {
"sql61Prop": {
"overrideHigherLevelSettings": {
"useLocalSystemAccount": false,
"overrideGlobalAuthentication": true
"MSSQLCredentialinfo": {
"credentialId": 123,
"credentialName": "Cred123"
$response = Invoke-RestMethod -Method Post -Body $body -Headers $headers -Uri $url + "/client/12345")
Response:
"processinginstructioninfo": {
"attributes": [
"name": "exitval",
"value": "0"
"response": [
"errorCode": 0,
"entity": {
"clientId": 12345,
"clientName": "client12345",
"_type_": 3
So successfully processed, but actually nothing is changed in the client.
With kind regards,
Maurice
