How to use access token generated in the web portal in API calls?
  • January 10, 2025
  • 9 replies
  • 430 views
I created an access token in the CV portal via “Security->Users->Access tokens->Add token” and the “Scope” was selected to “All”. However, when i tried to use the access token to send an API request like below, the server returned “Missing or invalid authorization header!”.
GET /v4/fileservers HTTP/1.1
Accept: application/json
Authorization: Bearer QSDK <access token generated in the portal>
Host: api.metallic.io
Connection: keep-alive
Appreciate if anyone knows how to use the access token.
In the Command Center you’re creating a bearer token, so the usage is
Bearer [and here the long string received during bearer token creation]
On the other hand, if you created a “regular” QSDK token ie. in /webconsole/sandbox, then the usage is
QSDK [and here the long string]
In total three headers are required:
        'Authorization' = '[here put QSDK or Bearer token]'
        'Accept' = 'application/xml'
        'Content-type' = 'application/json or xml'
Hope that helps.
  • January 10, 2025
Thank you so much for your quick response. I tried to reperform what you said but unfortunately it didn’t work. Are you aware of what I did wrong?
This seems to be metallic related… ​
  • January 11, 2025
Anyone can help with this? Thanks.
Took a bit:)
  • Run /login
  • Take the authtoken QSDK string from the output
  • Use the header Authorization: Bearer QSDK string
So an example to list hypervisors after getting authtoken as “QSDK 3ad83249f8395acaa54605aef429bf1a38a0d68c8e3f34e7fa136a15a8c0832d79f73109fd10629a4c29c” from /Login you’d run:
GET against https://api.metallic.io/v4/hypervisor with the below headers
"Accept: application/json"
"Content-type: application/json"
“Authorization: Bearer QSDK 3ad83249f8395acaa54605aef429bf1a38a0d68c8e3f34e7fa136a15a8c0832d79f73109fd10629a4c29c"
  • January 12, 2025
Thank you for the reply. The “/Login” case did work if i provide username and password. However, i have mulit-factor authentication enabled and i couldn’t just use username and password to get the access token from “https://api.metallic.io/Login”.
This is the reason why i want to generate the access token from the portal for long-term usage.
Interestingly, I have tested the same setup to get access token from my on-premise Commvault instance and it works fine. Just the cloud version didn’t work.
  • January 15, 2025
Got it. If all my cloud accounts are all MFA enabled, how can i authenticate to metallic APIs using “/login”?
It is quite simple:
You use your email as a username and base64 encoded password+pin from whatever TFA solution you’re using.
Example:
user: jacek@test.lab
regular password: #test123@
the PIN received from the 2FA app: 125486
the pass to provide to base64 encoder: #test123@125486
the string returned by the base64 encoder: I3Rlc3QxMjNAMTI1NDg2
the username to provide to REST /Login: jacek@test.lab
the password to provide to REST /Login: I3Rlc3QxMjNAMTI1NDg2
