how to work with List arays and for each
  • Aug 15, 2023 8:46 AM UTC
  • 64 views
Hello Community,
im wondering how to work with list(string) together with for each.
My customer needs to fill in a form with all the clients he needs into a multiline field like this.
how does the foreach activity goes to every line from the list?
Thats not how it works:
thanks a lot and regards
Jacob
Best answer by Jacob.sp
Found the problem.
Multiline doesnt create a Listsentry for every line.
Textbox with list enabled does:
  • Aug 15, 2023 11:47 AM UTC
Found the problem.
