How zabbix to collect commvault's alert, and one by one client?
  • April 7, 2025
  • 10 replies
  • 708 views
Forum|alt.badge.img+2
Backgroup:
Commvault is nice backup platform, and it is helpfull to us who are IT admins.
IT team charges the backup operation daily, and include over 400 clients; usually, the backup faild or other alert are gerented everyday, and only autherization user is able to login commvault software to check and fixe the alerts, but it not kindly way to share or push client’s owner to move on.
Originally, IT team want to use Zabbix collect the alert from Commvault, and now the way is successful.
  • April 7, 2025
Commvault is able to send alert by SNMP V3 to other platform, and create alert
Create new Alert rules, and send notification by SNMP;
attaction: “client name” is used to collect owne alert from alert pools, and “Threshold and Notification Criteria Selection” is alert information head to be used for create “Problems” in Zabbix.
Summary alert rule as below:
  • April 7, 2025
  • Zabbix install SNMP
yum -y install net-snmp net-snmp-agent-libs net-snmp-devel net-snmp-libs net-snmp-perl net-snmp-utils snmptt
yum -y install perl-Sys-Syslog
  • April 7, 2025
  • Configrate snmptraped in zabbix plantform
vim /etc/snmp/snmptrapd.conf
screenshot information should match with Commvault SNMP settings
  • April 7, 2025
  • change snmptt.ini
net_snmp_perl_enable=1
date_time_format = %Y/%m/%d %H:%M:%S
  • April 7, 2025
  • Add parsing rules in snmptt.conf
    EVENT general .iso.org.dod.internet.private.enterprises.14604.2.2.0.1003 "Commvault" Normal
    FORMAT ZBXTRAP $aA Host:$5 Hex-STRING:$6
    SDESC
    Commvault backup job Alert
    EDESC
  • April 7, 2025
  • change zabbix_server.conf to readsnmptt.log
StartSNMPTrapper=1
SNMPTrapperFile=/var/log/snmptt/snmptt.log
  • April 7, 2025
  • reboot service
systemctl restart snmptrapd
systemctl enable snmptrapd
systemctl restart snmptt
systemctl enable snmptt
  • April 7, 2025
  • Add new template
  • April 7, 2025
  • Add Commvault alert client
  • SNMP IP address must be commvault SNMP sent
  • Configration the alert Preprocessing
  • Change String
JavaScript as below:
var word = 'Hex-STRING:';
var index = value.indexOf(word) + word.length;
if (index !== -1) {
    value=value.substring(index).trim();
    value=value.replace(/\s+/g, '');
    var isHex = /^[0-9a-fA-F]+$/g.test(value);
    if (isHex) {
    var hexPairs = value.match(/.{1,2}/g);
    var decimalArray = hexPairs.map(function(pair) {
        return parseInt(pair, 16);
    var uint8Array = new Uint8Array(decimalArray);
    var decoder = new TextDecoder('utf-8');
    return value = decoder.decode(uint8Array);
    } else {
    return value;
The Commvault Client is able to collect all alerts from commvault SNMP.
  • April 7, 2025
  • add client to collect owner alerts
  • {$CV_HOSTNAME}: the value come from commvault client’s “name”
