Java imports failing
  • 15 March 2024
  • 58 views
The following imports:
import commvault.cte.workflow.activities.HttpClient;
import commvault.cte.workflow.types.WebRequest;
import commvault.cte.workflow.types.NameValue;
import commvault.cte.workflow.types.WebMethod;
Produces the following:
Script1.groovy: 8: unable to resolve class commvault.cte.workflow.types.WebRequest
@ line 8, column 1.
Script1.groovy: 9: unable to resolve class commvault.cte.workflow.types.NameValue
@ line 9, column 1.
Script1.groovy: 10: unable to resolve class commvault.cte.workflow.types.WebMethod
@ line 10, column 1.
Hi @christopherlecky
Which version are you using?
Which Workflow and version is this?
Sebastien
11.28,
Home cooked workflow. I just need to resolve those methods.
Ended up replacing it with basic java httpclient.
import java.net.http.HttpClient;
import java.net.http.HttpRequest;
import java.net.http.HttpResponse;
