Need an API endpoint to get the body for one of the APIs
  • July 22, 2024
  • 83 views
I was thinking about below API end-point: https://api.commvault.com/docs/SP32/api/cv/VirtualizationOperations/vsa-subclient-preview
Please help me with the API endpoint that output below body:
{ "appId": { "subclientId": 31, "clientId": 12, "instanceId": 4, "backupsetId": 0, "apptypeId": 106 } }
I will use the above body in the API : https://api.commvault.com/docs/SP32/api/cv/VirtualizationOperations/vsa-subclient-preview
My idea is to fetch the subclient id and from the subclient id I can retreive the subclient name and work without manually entering any details.
Best answer by Damian Andre
Subclient should be the equivalent of a VM group - here is the API to get VM groups:
https://api.commvault.com/docs/SP32/api/cv/OpenAPI3/get-all-vm-groups
You might be able to get the details you need on vm group details as well (which lists the content)
https://api.commvault.com/docs/SP32/api/cv/OpenAPI3/get-vm-group
  • July 24, 2024
@Damian Andre Thank you for your response.
I was getting multiple subclient Ids as the subclient is present under each of the VMs as well. So I enter the name of the Vcenter and fetch the Vcenter id which in turns help me fetch the subclient and it’s ids and it works.
I am able to update subclient content as well.
Thanks. This can be closed.
