Powershell login failed
  • June 21, 2022
  • 509 views
Forum|alt.badge.img+2
After the upgrade to Windows 10 21H2 I’m not able to login to the Commserve with Connect-CVServer cmdlet. I receive always “login failed” but I’m sure about username and password.
In the past I solved this problem using Internet Explorer to connect to Commserve once time, but now IE is not available in this version
Best answer by YNAP
Just to add an update, below the exact error:
VERBOSE: POST http://172.22.32.55:81/SearchSvc/CVWebService.svc/Login with -1-byte payload
VERBOSE: received -1-byte response of content type application/json; charset=utf-8
ValidateResponse :
Status:
Message: The response content cannot be parsed because the Internet Explorer engine is not available, or Internet
Explorer's first-launch configuration is not complete. Specify the UseBasicParsing parameter and try again.
ErrorMessage:
RecommendedAction:
At C:\Program Files\WindowsPowerShell\Modules\Commvault.RESTSession\2.0.21\Commvault.RESTSession.psm1:560 char:13
+             ValidateResponse $response $output $ValidateProperty
    + CategoryInfo          : NotSpecified: (:) [Write-Error], WriteErrorException
    + FullyQualifiedErrorId : Microsoft.PowerShell.Commands.WriteErrorException,ValidateResponse
I solved the problem following this link
Solving the First-Launch Configuration Error with PowerShell's Invoke-WebRequest Cmdlet - Wahl Network
creating a local GPO and running gpupdate /force on my laptop
Hi @YNAP !  Thanks for the post.  I spoke to the Manager of the team that handles these issues and he suggested creating a support case.  They are unaware of any issues like this and would need to do a deep dive.
  • June 22, 2022
ValidateResponse :
Status:
ErrorMessage:
RecommendedAction:
  • June 22, 2022
ValidateResponse :
Status:
ErrorMessage:
RecommendedAction:
Glad to hear it, @YNAP and thanks for sharing with the community!!
