qcommand / API to Power On the MediaAgent
  • Aug 9, 2023 9:07 AM UTC
  • 135 views
Forum|alt.badge.img+8
I would like to know if there is any qcommand/ API to power on the Media agent
Best answer by mikevg
Hello @alligator ,
There is an API call for it as the cvpysdk has it:
https://github.com/Commvault/cvpysdk/blob/master/cvpysdk/storage.py#L654
Mike
Forum|alt.badge.img+13
@alligator
Please try the below qcommand and let us know if this helps:
https://documentation.commvault.com/2022e/expert/setMediaAgentProperty.html
  • Aug 9, 2023 9:25 AM UTC
@Navneet Singh this is to set the media agent property,
I couldn’t find an option specifically to power ON or power Off the media agent
I dont want to change/modify media agent properties, rather an action to be performed,
to power on the media agent and power off without using GUI
@alligator
We don’t have any qscript to do this. Please raise a case so we can check with our dev team internally.
  • Aug 9, 2023 1:25 PM UTC
Hello @alligator ,
Mike
