Qcommand to get install directory on a client or mediaagent
  • July 18, 2021
  • 311 views
Best answer by SC2021
I’m not sure if there is a qcommand, but I get this information from the environment (local to the machine) or the registry (for local or remote machines):
echo %CV_Instance001%
C:\Program Files\Commvault\ContentStore\Base
reg query "HKLM\SOFTWARE\CommVault Systems\Galaxy\Instance001\Base" /v dBASEHOME
HKEY_LOCAL_MACHINE\SOFTWARE\CommVault Systems\Galaxy\Instance001\Base
dBASEHOME REG_SZ C:\Program Files\Commvault\ContentStore\Base
reg query "\\MyMediaAgent\HKLM\SOFTWARE\CommVault Systems\Galaxy\Instance001\Base" /v dBASEHOME
dBASEHOME REG_SZ D:\Apps\Commvault\Simpana\Base
Hi @prudhvi
Thanks for the question.
I have been checking through documentation and we have a few scripts to obtain client information,  but I can’t confirm whether installation directory is included in the results:
Available QScripts
Specifically, please take a look at:
GetClientDescription
GetClientInfo
GetClient_Info
I’m also checking if we have a report that will provide this data.
Stuart
  • July 22, 2021
As @SC2021 suggests, the install directory can be obtained from the client registry.
I have been checking available reports, but unfortunately I have been able to find a report that shows install directory data.
We do have this data in the Commserve database as you can see this detail on client properties in the GUI.
The best match I can find is Client Details Report, however as it doesn’t show install directory, you would need to clone the report and edit to include the additional field.
Stuart
