ResAPI for restore responding with error "ClientInfo is not complete","errorCode":9517
  • Feb 15, 2024 7:14 AM UTC
  • 7 replies
  • 275 views
Forum|alt.badge.img+2
I am trying to test the Retrieve to Client (Restore) API following the document  Retrieve to Client (Restore) | Commvault®.
I tested the API with both Postman and Golang, and both times I received an error in response. The error is pasted below.
Please see the sample GoLang code below. I followed the example in the Commvault rest API docs, but I can't figure out what's missing here.
package main
import (
"crypto/tls"
"fmt"
"io/ioutil"
"net/http"
"strings"
func main() {
url := "https://hostname/commandcenter/api/retrieveToClient"
method := "POST"
payload := strings.NewReader(`{
"mode": 2,
"serviceType": 1,
"userInfo": {
"userGuid": "da752adf-79f0-47d6-8be5-d3dadc9abc5e"
"advanced": {
"restoreDataAndACL": true,
"restoreDeletedFiles": true
"header": {
"destination": {
"clientId": 171,
"clientName": "<<clientname>>",
"inPlace": false,
"destPath": [
"C://Users//Administrator//Downloads"
"filePaths": [
"//C://Users//Administrator//Desktop//800gb"
"srcContent": {
"subclientId": 399,
"clientId": 171,
"instanceId": 1,
"backupSetId": 331,
"appTypeId": 33
client := &http.Client{}
http.DefaultTransport.(*http.Transport).TLSClientConfig = &tls.Config{InsecureSkipVerify: true}
req, err := http.NewRequest(method, url, payload)
if err != nil {
fmt.Println(err)
return
req.Header.Add("Content-Type", "application/json")
req.Header.Add("Accept", "application/json")
req.Header.Add("Authtoken", "QSDK 3b83bf1066977563d72cc4d5de464a5b4602376898a02ae6d0bb71b2203d48c1d76041e15edda9950eeb20242519e7c51a2a33c8a90d6c921d532e1f9b71c104f22fca2b87e0566fb6fa4aa12b6a3eb26036f77470d15f8468ab08ce41ce4b14d8017a898127d930021c4d9e37626fb2f8b025ad070dd3f8e998d0fdc8a0ae2ec865e1879aef4ee20081d6932753a8d9171c04870d64c090d4db4cf5e2696e5d8885d32b3db00d1d489d1774c9d0811aa83f2ec97b4639f64d45de8dc813d7967e5cf7f7304bb314a65920e0cb2b22e545ada376f28de827d65dc20ea48eb0dda3fbef4e598ed68fa")
res, err := client.Do(req)
if err != nil {
fmt.Println(err)
return
defer res.Body.Close()
body, err := ioutil.ReadAll(res.Body)
if err != nil {
fmt.Println(err)
return
fmt.Println(string(body))
Best answer by Jacek Piechucki
Please find below my working code.
The difference is provided client name.
The other important modification for Windows restores is using backslashes instead of slashes; otherwise browse process will not find data to restore.
package main
import (
    "crypto/tls"
    "fmt"
    "io/ioutil"
    "net/http"
    "strings"
func main() {
    url := "https://webconsolehostname/commandcenter/api/retrieveToClient"
    method := "POST"
  "mode": 2,
  "serviceType": 1,
  "userInfo": {
    "userGuid": "2AE69CA3-1DDA-4AB3-848D-DFCB06EC195D"
  "advanced": {
  "header": {
    "destination": {
      "clientId": 2,
      "clientName": "CS04-32",
      "inPlace": false,
      "destPath": [
        "C:\\users\\Administrator\\Downloads"
    "filePaths": [
      "C:\\inetpub\\logs\\LogFiles"
    "srcContent": {
      "subclientId": 3,
      "clientId": 2,
      "instanceId": 1,
      "backupSetId": 4,
      "appTypeId": 33
    if err != nil {
        fmt.Println(err)
        return
    req.Header.Add("Authtoken", "QSDK 3e165b4162d1221ad17fc6cc514a6d4eee0d575578132754627489f115c6917a7816c987a4247df7a577a9d64f27b738eb0ba58eca554f90f41450c18027230dfdc3ab16be0694eddeef0530d09afab3c24a41ed2881b64d5a463394b7f996b4df20a684fbbdd2b905542c576186e91a1bf147c3c3269d27671e73230255fb8df3d15856c6bf663994a249c337fbddf7185360e79ee475d0afc1f8952620abadd18ac00efd326cce909ddae30f0d312ff9faecf8d7980fa7bc4f65f70d1303763d41d8afde213e3b566021db58a6587bc")
    if err != nil {
        fmt.Println(err)
        return
    if err != nil {
        fmt.Println(err)
        return
Please set the debug level to 10 for webeserver.log on the client where webserver is running, wait a minute or two, replicate the issue and share the log snippet, sanitized, if necessary.
Kr,
Jacek
Hello @Jacek Piechucki ,
Thank you. Please find the log snippet below.
24568 176   02/14 23:34:51 176 hdpsauto  - WEBAPI-STARTED processing [POST]:[/retrieveToClient] request. : /retrieveToClient : Headers :[Accept=application/json][Accept-Encoding=gzip][Content-Length=625][Content-Type=application/json][Host=HOSTNAME:81][SkipOldJsonConverter=true][trace-id=ws1bf18d03f46f][WEBSERVERCORE-FLAG=true] : AdditionalInfo[ ConsoleType[API]ClientIP[<<CLIENT_IP>>] Operation[CV.WebServer.Controllers.ClientController.retrieveToClient (CVWebControllerClient)] isTokenSupplied?[True] Username[hdpsauto]] : Request : <DM2ContentIndexing_RetrieveToClientReq mode="2" serviceType="1"><userInfo userGuid="da752adf-79f0-47d6-8be5-d3dadc9cec5e" /><advanced restoreDataAndACL="1" restoreDeletedFiles="1" /><header><filePaths val="//C://Users//Administrator//Desktop//800gb" /><destination clientId="171" clientName="<<CLIENT_NAME>>" inPlace="0"><destPath val="C://Users//Administrator//Downloads" /></destination><srcContent subclientId="399" clientId="171" instanceId="1" backupSetId="331" appTypeId="33" /></header></DM2ContentIndexing_RetrieveToClientReq>
24568 176 02/14 23:34:51 176 hdpsauto GetService - lookup for requested interface IWebSessionInfoService among registered services succeeded.
24568 176 02/14 23:34:51 176 hdpsauto <validator> - Verifying Client.retrieveToClient arguments.
24568 176 02/14 23:34:51 176 hdpsauto <validator> - Client.retrieveToClient parameter 'RetrieveToClientReq req' is set and valid
24568 176 02/14 23:34:51 176 hdpsauto <validator> - All arguments are OK. Continue Client.retrieveToClient execution.
24568 176 02/14 23:34:51 176 hdpsauto GetService - lookup for requested interface ICVIDAEntityDbContext among registered services succeeded.
24568 4668 02/14 23:34:51 ### GetNumberFromGalaxyRegistry()() - Retrival of Number from Galaxy Registry failed with Error code [0x303] Error string [Invalid Argument]
24568 63c 02/14 23:34:51 ### getQSDKTokenInfo() - Found matching token for provided CS.
24568 168 02/14 23:34:51 ### hdpsauto dmSecurity::GetProviders - Host name or proxy name is empty for name server #[0]. Firewall config check skipped.
24568 168 02/14 23:34:51 ### hdpsauto dmSecurity::GetProviders - Host name or proxy URL is empty for name server #[0]. Firewall config check skipped.
24568 168 02/14 23:34:51 ### hdpsauto dmSecurity::GetProviders - Host name or proxy name is empty for name server #[1]. Firewall config check skipped.
24568 168 02/14 23:34:51 ### hdpsauto dmSecurity::GetProviders - Host name or proxy URL is empty for name server #[1]. Firewall config check skipped.
24568 168 02/14 23:34:51 ### hdpsauto Login:GetDomains - Service details are not returned for security reason
24568 176 02/14 23:34:51 ### hdpsauto csSecurity::getBrowseClientsContents - Input --> userGuid : [B98A5], fromTime : [0], toTime : [0]
clientId : [171, serviceType : [1], mailBoxorNFS : [],mode = [0]
24568 176 02/14 23:34:51 176 hdpsauto ShouldVisit - Message is not supported for company tagging
24568 176 02/14 23:34:51 176 hdpsauto Invoke - WEBAPI-FINISHED processing [POST]:[/CVWebService.svc/retrieveToClient] in [230] ms; HTTP code 'OK' Out : <DM2ContentIndexing_RetrieveToClientResp><errList errLogMessage="ClientInfo is not complete" errorCode="9517" /></DM2ContentIndexing_RetrieveToClientResp>
24568 1454 02/14 23:36:16 ### CVPlatformInfo::getRegStringImpl() - Field messagequeueTCPPort in key ~MessageQueue is not a string.
package main
import (
    "crypto/tls"
    "fmt"
    "io/ioutil"
    "net/http"
    "strings"
func main() {
    method := "POST"
  "mode": 2,
  "serviceType": 1,
  "userInfo": {
  "advanced": {
  "header": {
    "destination": {
      "clientId": 2,
      "inPlace": false,
      "destPath": [
    "filePaths": [
    "srcContent": {
      "subclientId": 3,
      "clientId": 2,
      "instanceId": 1,
      "backupSetId": 4,
      "appTypeId": 33
    if err != nil {
        fmt.Println(err)
        return
    if err != nil {
        fmt.Println(err)
        return
    if err != nil {
        fmt.Println(err)
        return
I made the changes according to your suggestion, but I am still getting the same error message.
Code:
package main
import (
"crypto/tls"
"fmt"
"io/ioutil"
"net/http"
"strings"
func main() {
method := "POST"
"mode": 2,
"serviceType": 1,
"userInfo": {
"userGuid": "da752adf-79f0-47d6-8be5-d3dadc9cec5e"
"advanced": {
"header": {
"destination": {
"clientId": 171,
"clientName": "win-knp93b9ojtb",
"inPlace": false,
"destPath": [
"C:\\Users\\Administrator\\Downloads"
"filePaths": [
"C:\\Users\\Administrator\\Desktop\\800gb"
"srcContent": {
"subclientId": 399,
"clientId": 171,
"instanceId": 1,
"backupSetId": 331,
"appTypeId": 33
if err != nil {
fmt.Println(err)
return
req.Header.Add("Authtoken", "QSDK 3b9fd47dac7abd89831dce09cba43bc04c6ba32156b51f9dbf7fb5f99db7090353fa5ce7f5f22da66c2debabf6908487487bfa379da1b0e775b43d93055330802218d8488d60efbff5a7b35027f7783b5ec661481b6b5b11569a33235635f074f15381ba9822db94b3e60a79e77e564b511218e5286f91e104df614969e02c1e442c20f45076e7499cc5e441c57373178bfd3aba6ffc417eaaebb2d2d8b4041f2bd91f369563c1641bc661ccff1f96a21f5d88e111c3a78b86cb222ffb4084099f126307e316fc0498925b7306b18f22775e2e3bed495b37d")
if err != nil {
fmt.Println(err)
return
if err != nil {
fmt.Println(err)
return
WebServer.log
3904 130   02/15 03:51:15 130 hdpsauto GetService - lookup for requested interface IWebSessionInfoService among registered services succeeded.
23904 130 02/15 03:51:15 130 hdpsauto <validator> - Verifying DM2Messages.GetDomains arguments.
23904 130 02/15 03:51:15 130 hdpsauto <validator> - All arguments are OK. Continue DM2Messages.GetDomains execution.
23904 130 02/15 03:51:15 130 hdpsauto ShouldVisit - Message is not supported for company tagging
23904 130 02/15 03:51:15 130 hdpsauto Invoke - WEBAPI-FINISHED processing [GET]:[/CVWebService.svc/getDomains] in [149] ms; HTTP code 'OK' Out : <DM2ContentIndexing_GetLogonListResp><domains serviceType="2" hostName="SelfCert.Com" resourceId="0" flags="1" isCS="0" enabled="1" servicePassword="" port="0" domainName="SELFCERT" secureLDAP="0" id="1" serviceUserName="" /></DM2ContentIndexing_GetLogonListResp>
23904 116 02/15 03:51:15 116 hdpsauto Invoke - 'POST /CVWebService.svc/retrieveToClient' is not found in CVWebServerCoreRouting.conf. Will be handled by WebServerCore
23904 116 02/15 03:51:15 116 hdpsauto Invoke - IP [Client_IP] is not a trusted ip source
23904 116 02/15 03:51:15 116 hdpsauto Invoke - Mode is not a trusted mode [QSDKToken]
23904 116 02/15 03:51:15 116 hdpsauto TokenTypeAndApiMatches - API '/retrievetoclient' does not check the token type.
23904 116 02/15 03:51:15 116 hdpsauto Invoke - authenticated = True, bAuthRequired = True, refuse = False
23904 116 02/15 03:51:15 116 hdpsauto Invoke - RemoteWebServiceHelper.IsRemoteServiceRequest returned false
23904 116 02/15 03:51:15 116 hdpsauto - WEBAPI-STARTED processing [POST]:[/retrieveToClient] request. : /retrieveToClient : Headers :[Accept=application/json][Accept-Encoding=gzip][Content-Length=623][Content-Type=application/json][Host=WIN-C7K6LI9LPL7:81][SkipOldJsonConverter=true][trace-id=wsba8dadf035b3][WEBSERVERCORE-FLAG=true] : AdditionalInfo[ ConsoleType[API]ClientIP[172.18.105.206] Operation[CV.WebServer.Controllers.ClientController.retrieveToClient (CVWebControllerClient)] isTokenSupplied?[True] Username[hdpsauto]] : Request : <DM2ContentIndexing_RetrieveToClientReq mode="2" serviceType="1"><userInfo userGuid="da752adf-79f0-47d6-8be5-d3dadc9cec5e" /><advanced restoreDataAndACL="1" restoreDeletedFiles="1" /><header><filePaths val="C:\Users\Administrator\Desktop\800gb" /><destination clientId="171" clientName="win-knp93b9ojtb" inPlace="0"><destPath val="C:\Users\Administrator\Downloads" /></destination><srcContent subclientId="399" clientId="171" instanceId="1" backupSetId="331" appTypeId="33" /></header></DM2ContentIndexing_RetrieveToClientReq>
23904 116 02/15 03:51:15 116 hdpsauto GetService - lookup for requested interface IWebSessionInfoService among registered services succeeded.
23904 116 02/15 03:51:15 116 hdpsauto <validator> - Verifying Client.retrieveToClient arguments.
23904 116 02/15 03:51:15 116 hdpsauto <validator> - Client.retrieveToClient parameter 'RetrieveToClientReq req' is set and valid
23904 116 02/15 03:51:15 116 hdpsauto <validator> - All arguments are OK. Continue Client.retrieveToClient execution.
23904 116 02/15 03:51:15 116 hdpsauto GetService - lookup for requested interface ICVIDAEntityDbContext among registered services succeeded.
23904 116 02/15 03:51:16 116 hdpsauto ShouldVisit - Message is not supported for company tagging
23904 116 02/15 03:51:16 116 hdpsauto Invoke - WEBAPI-FINISHED processing [POST]:[/CVWebService.svc/retrieveToClient] in [384] ms; HTTP code 'OK' Out : <DM2ContentIndexing_RetrieveToClientResp><errList errLogMessage="ClientInfo is not complete" errorCode="9517" /></DM2ContentIndexing_RetrieveToClientResp>
23904 116 02/15 03:51:15 ### hdpsauto csSecurity::getBrowseClientsContents - Input --> userGuid : [B98A5], fromTime : [0], toTime : [0]
The only thing I can think of is a confusing / incorrect set of data given for destination or source elements and provided to the API.
Thanks @Jacek Piechucki ,
The issue has been resolved. The backup I tried to restore was pruned because its retention time had expired. I took a fresh backup today, and the problem is now resolved.
I believe the REST API page should be modified to use backslashes rather than slashes in the file path.
Also, could you please provide an example of a Linux path?
Good morning everyone. Thanks to this post I was able to solve the same problem I was having. But I'm only able to do it from Windows to Windows. I now need to do it from NAS to NAS. What should the setup be? I'm getting error 9517 again.
<header>
    <srcContent
            subclientId="488"
            clientId="131"
            instanceId="1"
            backupSetId="141"
            appTypeId="13"
    <filePaths val="/__VOLUME__/ADM_Teste/teste.csv"/>
    <destination
            clientId="2181"
            subclientId="3340"
            inPlace="0">
      <destPath val="/svm_nasrs/Arquivo/teste"/>
    </destination>
