REST API SSL certification issue
  • October 29, 2021
  • 534 views
Juergen
Explorer
When I access the REST API via http://<<server>>:81/SearchSvc/CVWebService.svc/ it is working with all API commands, now I started to use REST API reports, like:  http://<<server>>:81//webconsole/api/crreportsplusengine/datasets/ now I get a SSL error ssl.SSLError: [SSL: WRONG_VERSION_NUMBER] wrong version number (_ssl.c:1129)
I send my requests via python 3.9 with ”requests.get(service, headers=headers)”
commvault version 11.20.55
any idea what is going wrong?
thanks
regards Jürgen
Best answer by HolowEd
@Juergen
Can you try to access the Rest API report using port 80. As the webconsole is access via tomcat and not the webserver,  please try to access via either of these url  http://<<server>>:80//webconsole/api/crreportsplusengine/datasets/  or  https://<<server>>//webconsole/api/crreportsplusengine/datasets/
  • October 29, 2021
@Juergen
Juergen
Explorer
  • October 29, 2021
@HolowEd
Thanks for your response.
I tried with port 80, now I get this error:
<!DOCTYPE html>
<html>
    <head>
        <title>A potentially dangerous Request.Path value was detected from the client (:).</title>
        <meta name="viewport" content="width=device-width" />
        <style>
regards juergen
  • October 29, 2021
@Juergen
What is the REST API call that you are using.
Juergen
Explorer
  • October 29, 2021
@HolowEd
http://<<server>>:80/webconsole/api/crreportsplusengine/datasets/<<datasetID>>:<<datasetID>>/data/
this is out of the report SubClient Backup Coverage
regards Juergen
@Juergen the api should be
api/cr/reportsplusengine and not api/crreportsplusengine
