Restore SQL database to Availability Group
  • April 2, 2024
  • 120 views
via Command Center it is not possible to restore a SQL-database “in place” to an availability group.
Does anybody have a workflow or Powershell-Script that can remove the database from the availability group before the restore … and back to the availability group after the restore?
Any help is very much appreciated.
Best regards.
Michael
Hello @Michael Seickert
In regards to your question you can use the Pre/post script option if you build your own PowerShell script to run.
https://documentation.commvault.com/2023e/expert/pre_processes_and_post_processes_overview.html
The following commands are ones that can be used in that script:
Remove Database:
https://learn.microsoft.com/en-us/powershell/module/sqlps/remove-sqlavailabilitydatabase?view=sqlserver-ps
Add Database:
https://learn.microsoft.com/en-us/powershell/module/sqlps/add-sqlavailabilitydatabase?view=sqlserver-ps
Kind regards
Albert Williams
Remove Database:
Add Database:
Kind regards
Albert Williams
Hi Albert,
This was exactly, what I am was looking for. I will try this.
Thank you.
Best regards.
Michael
