Script to Modify Subclient
  • 29 March 2021
  • 552 views
Badge +2
Hello
Is it possible to modify subclient using command line/powershell?
The backup content name changes every day and i would like a way to update the subclient content automatically without me having to upgrade the file to backup.
We are running commvault v11.22.13
Best answer by Damian Andre 29 March 2021, 19:45
Badge +14
You could use the Command Line to update the content path of the subclient, see the following link: Modifying a Windows File System Subclient from the Command Line Interface (commvault.com)
Michael
Badge +2
Hi Michael
Using your link i was able to modify the content of the subclient.
Is it possible to add multiple content path using the switch -content/path <path> or is it one path per command?
For example
qoperation execute -af update_subclient_add_template.xml -clientName Test1 -subclientName SubTest1 -contentOperationType ADD -content/path '/Test1/SubTest2/BackupFile','/Test1/SubTest2/BackupFile2'
Hi Michael
For example
Hi @LLL,
The qoperation command does not support multiple paths at once, so you’d have to run it several times to achieve all the paths you need.
Alternatively, if you would like to add multiple paths for the sub-client contents with a single command you can use qoperation exec instead, and provide an XML input file. You will need to do so by modifying the XML directly as mentioned in the documentation here:
https://documentation.commvault.com/commvault/v11/article?p=18670.htm
You can specify multiple paths to your subclient content as shown in the following example:
<content>
<path>C:\Documents and Settings</path>
</content>
<content>
<path>C:\Users</path>
</content>
<content>
<path>C\backupFolder2</path>
</content>
<content>
<path>C:\backupfolder3</path>
</content>
